This command clears all IS-IS counters for one or all VLANs.
| vlan all | Clears the counters for all VLANs. |
| vlan_name | Specifies a single VLAN for which counters are cleared. |
N/A.
This command only affects VLANs that have been added to IS-IS router processes. The following counters are cleared: adjacency changes, adjacency initialization failures, rejected adjacencies, ID field length mismatches, maximum area address mismatches, authentication type failures, authentication failures, DIS changes, hello PDU TX and RX count, LSP TX and RX count, CSNP TX and RX count, PSNP TX and RX count, unknown PDU type TX and RX count.
The following command clears the IS-IS counters for all VLANs:
clear isis counters vlan all
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
